Two years after the high-def home video format war ended, Blu-ray is finally starting to trickle into the mainstream. This has a lot to do with consumer awareness, as well as price drops. OK -- it has a lot to do with price drops. A $1200 standalone high definition disc player is interesting to early adopters. A $200 (or less) Blu-ray player that can stream content from the internet is interesting to quite a few more.
Before you start bargain shopping for the least expensive Blu-ray player you can find, know that you will need a few other things to get high-def goodness and there are certain features available only on step-up models that might be useful to you. First, you'll need an HDTV. For the best result, we recommend a 1080p TV so you can see the full detail that Blu-ray and high def streaming providers can deliver. You'll also need HDMI cable to connect the two devices. And if internet-based features like BD-Live and movie-streaming are important to you, then you'll need a home network with access to the internet. Most players require a hard-wired network connection (or an optional wireless bridge), though there are a few players available with built-in WiFi support.
Next, think about Blu-ray movies. You don't need to run out and upgrade every DVD you've ever owned. Chances are you can't anyway. Not every movie title is available on Blu-ray -- at least not yet. Just know that your old copy of The Matrix on DVD isn't magically going to turn into high definition quality when you play it on a Blu-ray polayer; even a new copy of Zombieland needs to be a Blu-ray to make high-def magic. However, those standard-def discs don't just make great coasters; they still play in your Blu-ray player. Even better, Blu-ray players "upconvert" that SD content to high definition resolutions, making the image appear even better than it did on your old DVD player.
Blu-ray isn't just about the video, but also offers a boost on the audio side. Because Blu-ray offers more storage space, the disc can dedicate more room to audio than a DVD ever could. Combine this with the latest compression technologies from Dolby and DTS and you'll get audio that can really give your home theater system a workout. Some of these new formats (Dolby TrueHD, DTS-HD Master Audio and multi-channel uncompressed PCM), can actually reproduce the original studio master tapes with no loss of detail or resolution. You'll want a player that supports these new formats in order to take full advantage of Blu-ray's audio capabilities.
Also, if you're still rocking with an older A/V receiver with no HDMI ports, then look for a player with multi-channel analog outputs (5.1/7.1). These will allow you to reap the full audio quality of Blu-ray even from an older receiver (as long as your receiver has multi-channel inputs).
Beyond the DVD
Audio and video aside, Blu-ray also has a few goodies for geeks that want more from their favorite movies. New players boast interactive and online features, also known as Bonus View (BD-Rom Profile 1.1) and BD-Live (BD-ROM Profile 2.0). BonusView allows you to watch video commentary from a director, cast or crew in a PiP Window while the movie is playing. And BD-Live allows you to connect to the web, though an Ethernet or wireless connection, depending on your player. From there, you can view special content or interact with other movie fans. Not every player is compatible right out of the box, though. Internal storage of at least 1 GB (Gigabyte) is needed; otherwise, you'll need to plug in a USB drive or SD card (depending on the player) with a minimum of 1GB of storage available.
Speaking of goodies, many new players are adding media streaming capabilities, such as Netflix, VUDU, Amazon Video-on-Demand, CinemaNow and Pandora streaming. Some players, such as those from LG and Samsung, can also access media files from your home network via DLNA-compatibility. If you like to get your music, movies and photos from more than just shiny silver discs, then you might consider one of these players. Selection of Internet-based content varies from brand to brand, so make sure the player you buy has all the content features you want.
If you're a gaming geek and can pry your face away from Call of Duty for five minutes, you'd know that Sony's PlayStation 3 also doubles as a Blu-ray player. However, there are plenty of other players on the market. Here are some of the ones to look out for in 2010.
Note that, unless otherwise noted, all models below include support for BD-Live and Bonus View as well as on-board decoding of DTS-HD and Dolby TrueHD to PCM output over HDMI as well as bitstream output of these audio formats.
In April, Denon announced two 3D-ready Blu-ray players, which will each sport HDMI 1.4a outputs. Denon plans to release the 3D firmware upgrade this fall. In the meantime, you can use the DBP-2011UDCI and DBP-1611UD to play Blu-rays, DVD-Audio and SACDs.
Both units have streaming Netflix and YouTube features, as well as a 1GB of on-board memory for BD-Live playback. If you want to up that option, add an external memory device to either player via the USB jack. Other features include Kodak Picture CD compatibility, as well as DivX HD+, MP3 and WMA playback.
Also noteworthy, the DBP-2011UDCI features the very latest Anchor Bay Technologies decoding Engine and Scalar, as well as all-new Burr-Brown 32-Bit, 192-kHz Audio DACs on all channels.
Earlier this year, Denon announced the S-5BD BD/Receiver. It's exactly what it sounds like, packing a 5.1-channel surround sound receiver and Profile 2.0 Blu-ray player into one component.
The S-5BD features HDMI 1.4 with support of Audio Return Channel, SD card inputs, iPod connectivity, and multi-channel analog outputs (5.1/7.1). Priced at $1799, the S-5BD should be available in March.
Until then, the company is still selling several models introduced in 2009, including DBP-4010UDCI, which is well worth a look. After all, the 4010UDCI could be considered the perfect all-in-one solution for the audiophile, offering playback of DVD-Audio and SACD titles as well. The 4010UDI and the DBP-2010CI have 7.1 ouputs. The entry-level DBP-1610 does not, but offers BD-Live as well as internal decoding of DTS-HD and Dolby TrueHD.
Insignia
JVC
JVC has not announced a new Blu-ray offering for 2010. However, the XV-BP11 is still pretty popular for the company. This entry-level unit does not do BD Live, but it's a nice starter unit, with 1080p playback and AVCHD support, which makes it easy to incorporate your own content from HD video cameras, most notably the JVC HD Everio line. The unit features an HDMI output in the back and a USB jack on the front. However, the best feature is that the XV-BP11 can be had for an actual street price of around $130.
LG
Aside from the typical 1080p playback, LG's 2010 models feature NetCast, which provides access to services like Netflix, VUDU, Picasa, YouTube, Cinema Now, AccuWeather.com and Pandora, all on your big screen (and/or through your Big Speakers). The BD550 is the standard model. The BD570 throws in built-in Wi-Fi, while the BD590 also includes WiFi and is the first LG player to feature a 250GB hard drive. That hard drive comes in handy, since VUDU offers more than 3,000 high-def videos for purchase. The BD590 has another first: Gracenote's MusicID-Stream. Next time you can't name that tune in a movie or TV show, just tap a button on your remote and this feature will provide the song title, artist and album cover art. The BD590 also offers multi-channel (5.1/7.1) analog output for compatibility with older gear.
Marantz
Marantz hasn't made any announcements so far this year. That doesn't mean they aren't coming. For now though, they are still selling four models, all of which came out in late 2009. The UD9004 is considered to be the company's flagship player, offering playback of CDs, SACDs, DVD-Audio discs, and Blu-ray titles (duh). Also know that the audio portion of the UD9004 is based on Marantz's award-winning SA-7S1 Reference SACD Player.
The UD9004, as well as the UD7004 and UD8004, all feature 7.1-channel inputs. The UD5004 does not, but has a front panel slot for SD/SDHC memory cards and support for DivX and AVCHD files.
NAD
The M56 and 2009's T 577 both feature 7.1-channel audio inputs. Another 2009 model, the T 557, does not. However, it does have onboard decoding for Dolby TrueHD and DTS Master Audio 7.1 formats.
Onkyo
This year's BD-SP807 gets the stamp of approval from THX, and features 7.1-multichannel audio outputs and NSV video processing. The unit also has an HDMI Source Direct mode, which can output the video signal in its native resolution, for processing on your A/V receiver. On the audio side, the BD-SP807 promises studio-master quality of Dolby TrueHD and DTS-HD Master Audio Essential. Onkyo's 2009 release, the DV-BD507, is also still shipping
OPPO
The latest for OPPO is the entry-level BDP-80, the first OPPO Blu-ray player under $300. Like OPPO's 2009 players, the BDP-83SE and BDP-83, which are still current units, this new player plays DVD-Audio and SACD discs, as well as CDs, DVDs and Blu-ray Discs.
The BDP-80's video processing is not as advanced as the BDP-83, but it offers a "Source Direct" output mode, which outputs video in the native source resolution. This makes the player perfect for use with external video processors, A/V receivers with built-in video processing, and high-end display devices with built-in video processing. The BDP-83SE (Special Edition), is a souped up version of the BDP-83, offering the highest audio and video performance in the line.
All of the current OPPO players feature multi-channel analog outputs (up to 7.1 channels) with the ability to boost the subwoofer output (a rare feature indeed). This makes them excellent choices for compatibility with older non-HDMI home theater audio systems. As of the publication of this article, OPPO has no IPTV or content streaming features, though it can play audio, photo and video files from devices attached to its USB port.
Panasonic
Last year, we got to play around with Panasonic's DMP-BD70V Blu-ray/VHS player, which is still current in the 2010 line-up. This year, we got our hands on the DMP-BD65 and BD85, albeit only briefly at a press event (full reviews coming soon). However, those are just two of Panasonic's five new players for the year. The DMP-BD45 is your basic model, with the usual high-def playback, but no BD-Live or networking capabilities. The other four models, the DMP-BD65, DMP-BD85, DMP-BDT300 and DMP-BDT350, all feature the latest version of VIERA Cast, which has just added Netflix, Pandora (coming in a a firmware upgrade), Twitter and Fox Sports content in addition to YouTube and Amazon Video on Demand.
The BD65 supports wireless internet access, but you'll need to buy the DY-WL10 USB/WiFi adapter separately. The BD85 throws in the WiFi adapter, as well as something called "Digital Tube" sound effects, which makes your audio sound like it's coming from a tube amplifier (how deliciously retro!) and digital anti-jitter circuitry to improve the sound over HDMI or analog outputs. The BD85 also offers multi-channel analog outputs (5.1/7.1) for compatibility with older gear. The BD85 also gets more advanced video processing circuitry (not available in the BD45 and BD64) which improves video performance on both DVDs and Blu-ray Discs, particularly in chroma (color) performance.
The DMP-BDT350 was the first 3D model that Panasonic announced (expected availability is Spring, 2010). It's basically equivalent to the DMP-BD85, but with the addition of Blu-ray 3D support plus DLNA networking and an even more advanced video processor which Panasonic calls "Super Resolution" processing. In early March, Panasonic unveiled the DMP-BDT300, another Blu-ray 3D player which is almost identical to the top of the line BDT350, except it has no DLNA networking and is $50 cheaper. It's available now only in Best Buy locations which include a Magnolia store within a store.
Pioneer
Pioneer couldn't give us a sneak peek of what's coming this year, but they are still pretty big on Blu-ray. The company says they are planning to announce a line this spring or early summer, with more maybe coming in the fall. However, details and model numbers haven't quite been finalized yet. For now, they are still pushing 2009's BDP-120, BDP-320 and Elite BDP-23FD. All three support BD Live, with the BDP-320 and Elite BDP-23FD also throwing in multichannel (5.1/7.1) analog audio outputs.
Samsung
Samsung has a slew of new Blu-ray players for 2010. At January's Consumer Electronics Show, the company was showing off the BD-C7500, BD-C5500, BD-C6500 and BD-C6900. The C7500 is Samsung's slimmest player to date, while the C6500 boasts high speed disc loading and a robust set of networking features (including DLNA and Netflix streaming). The C6900 is the standout, though, since it's Samsung's first Blu-ray 3D model. Both the C6500 and C6900 also feature 7.1-channel analog outputs.
All of the players feature Samsung's improved Internet@TV service, which provides access to Netflix, Picasa, Pandora, The AP, VUDU, and many other content providers. Samsung's not quite done yet, though; additional player models will be rolling out later this year.
Sharp
Sony
Announced earlier this year, Sony's BDP-S370, BDP-S470, BDP-S570 and BDP-S770 all feature enhanced BRAVIA Internet Video content, which includes Netflix, Amazon On Demand and YouTube. The new models are also compatible with BD Remote, a free app that allows users to control each of the players via an iPhone/iPod touch. Models also feature Sony's Entertainment Database Browser with Gracenote technology, which shows off disc cover art, actor, and production information. Of course, Sony is also planning to make the S570 and S770 compatible with 3D content, via a summer firmware upgrade.
Toshiba
Toshiba came late to the Blu-ray party, releasing its first player, the BDX2000, late in 2009. However, they are certainly making up ground by releasing three players this year. The BDX2500, BDX2700 and BDX3000 all feature 7.1-channel outputs, as well as streaming entertainment from Netflix, Blockbuster on Demand, Pandora, and VUDU. The difference here is that the 2700 has built-in wireless connectivity. The BDX2500 will require an adapter, which is sold separately. Also, the BDX3000, which ships later this year, will have a fresh design and 3D features.
VIZIO
In 2009, VIZIO unleashed its first Blu-ray player, the VBR110. Just a few months later, they launched the VBR200W, for under $200. The 200W boasts integrated Wi-Fi and HD 7.1 channel audio in the lossless high-resolution Dolby TrueHD and DTS-HD Master Audio formats. However, it's also got an endless source of entertainment via VIZIO Internet Apps (VIA). Those apps include Netflix, VUDU and Pandora, among others.
This year, the company launched three new players, the VBR210, VBR220 and VBR231. All three feature the VIA service, as well as built-in Wi-Fi. The 210 and 220 each have single-band 2.4GHz 802.11n support, while the 231 uses both the 2.4 and 5GHz bands.
Yamaha
Yamaha has yet to announce anything for 2010. In September, they announced the BD-S1900 and BD-S1065. Designed to work with Yamaha's AV receivers, the S1900 has 7.1 multi-channel output with four 2-channel DACs, an RS-232 interface, and direct bitstream and multi-channel Linear PCM outputs via HDMI. The S1065 is very similar, except it stands out via a soft blue LED display.
