Samsung 67-inch 1080p HDTV: $1499.99 with Stand (HL67A510)
Sure, flat panel HDTVs are cool, but if you want a really BIG screen flat panel (65 inches or more), then be prepared to plop down a cool $5Gs (yes, five thousand dollars). If you've got some space, and a hankering for that really BIG PICTURE, then you can't do much better than this new deal from Tiger Direct. They're offering Samsung's 67-inch DLP HDTV (the HL67A510) for a low $1499.99 including a free matching stand. That's a savings of $600 off list.
Here's the link to check out this deal:
This is a brand new (factory fresh) 1080p HDTV, with full manufacturer's warranty. It features a respectable 10,000:1 Contrast Ratio, on-board ATSC and QAM digital tuners and three HDMI inputs for compatibility with the latest high definition sources like Blu-ray Disc, HD cable and satellite set-top boxes.
Samsung HL67A510 Specifications from the Manufacturer:
Video
Screen Size
67''
Aspect Ratio
16 : 9
Resolution
1920 x 1080
Contrast Ratio
10,000:1
DNIeā¢
Yes
Digital Noise Reduction
Yes
Audio
Sound Effect System
DNSe
Sound Output(RMS)
10 W x 2
Input & Output(Side)
composite (AV)
1
S-Video
1
Input & Output(Back)
HDMI
3
composite (AV)
2
S-Video
2
PC input (D-sub)
1
Component(Y/Pb/Pr)
2
System
Tuners
NTSC / ATSC, Clear QAM
Dimensions
Set size(WXHXD) with stand
62.4" x 44.2" x 19.1"
Set size(WXHXD) without stand
62.4" x 44.2" x 17.8"
Package size(WXHXD)
67.9" x 48.9" x 23.4"
Weight
Set weight without stand
97.9 lbs.
Package weight
129.0 lbs.
Please note: all deals posted on Big Picture Big Sound are current as of the posting date and time. These deals are frequently time- or stock-limited and generally do not last. Final pricing and stock are determined by the individual deal provider, not by Big Picture Big Sound so you will need to click through on the offer link to see if it is still available. Through our affiliate relationships with many online vendors, Big Picture
Big Sound may earn a small commission on any referred sale.
