My TV Has No Audio Outputs, How Can I Connect to a Home Theater Receiver?
How do I get audio out from my LG 42LD520 TV into my Sony home theater system with my TV having no audio outputs?
Thanks,
-Jonathan
Dear Jonathan,
While your LG TV doesn't have a set of analog RCA audio outputs, it actually does have two audio outputs that you can use to connect it to a home theater system, soundbar or audio receiver.  It has a fiberoptic (TOSLINK) digital output. This would use a standard fiberoptic cable, but only if your home theater system has an available fiberoptic input. The same cable would work with most soundbars.
Chris Boylan - Ask the Expert
Your HDTV also has a headphone output, which you can connect to stereo RCA inputs using a simple stereo 1/8" to RCA adapter cable.
Here are a couple of choices:
You could plug either of these cables (analog or digital) into your home theater system, depending on the inputs available on your receiver. The fiberoptic digital connection is preferred as it will allow you to get Dolby Digital 5.1 surround sound from broadcasts that include it.
Digital fiber optic cables are used to carry sound to and from a number of different audio/video devices.
If you have a cable or satellite set-top box or DVR you could also plug the audio output of that box directly into your home theater system. Again, the fiberoptic or coax digital connection is preferred, or you could use the HDMI output if your home theater system supports HDMI inputs with audio processing.
Hope that helps,
Related:
