Deal Alert: 32 inch LCD Flat Panel HDTV - Under $800 (Syntax Olevia LT32HVM)
As the latest sign of the plummeting prices of flat panel HDTV, Buy.com is now offering the Syntax Olevia 32 inch HDTV-ready flat panel LCD TV (model LT32HVM) for just
$799.99 after a $300 manufacturer's rebate (rebate expires December 31 but Buy.com's pricing may expire sooner).
If the unit is no longer in stock, or pricing has changed, check out these related deals:
HDTV vs. HDTV-Ready?
Still wondering what's the difference between HDTV and "HDTV-ready?" Well, the only difference is that an HDTV comes with a built-in ATSC tuner so you can receive HDTV signals broadcast over the air using an antenna. An "HDTV-ready" TV offers the full resolution and picture quality of an HDTV, but without the high definition tuner.
But if you get your HDTV via cable or satellite, then you actually don't need the tuner - just plug in your high definition cable box or satellite receiver into this unit's component video or DVI input, sit back and enjoy the true high definition resolution of this LCD flat panel.
Olevia's Syntax LT32HVM features a dynamic brightness and contrast feature designed to deliver the best quality picture at all times. as well as variable edge enhancement circuitry. The LT32HVE includes audio enhancements such as lip sync compensation and preset equalization optimized for different types of music. movies and spoken word programming.
The LT32HVM includes an integrated standard definition NTSC tuner and built-in speakers for use as a standalone TV plus inputs for composite video, S-Video, component video and DVI with HDCP compatibility. The unit also includes a VGA input with an audio line input for use as a computer monitor.
Features and Specs of Syntax Olevia LT32HVM:
- Aspect Ratio: 16:9
- Brightness: 800cd
- Contrast: 1200:1 (Dynamic)
- Panel Resolution: 1366 x 768
- Response Time: 8ms
- Viewing Angle: 176 degrees (Horizontal) / 176 degrees (Vertical)
- 2:2/3:2 Pull Down Compensation
- Color Temperature Adjustment
- Digital 3D Comb Filter
- Progressive Scan
- Supported Resolutions: 480i, 480p, 720P, 1080i
- TV System Support: NTSC
- TV Tuner Input RF x 1
- Dimensions: 39.8" (W) x 22" (H) x 11.1" (D)
- Net Weight: 51 lbs
Power Consumption: AC 135 Watts- Wall Mounting Type VESA 100 x 200
Inputs and Outputs:- Stereo RCA Audio output x 1
- Earphone Output Stereo Mini (1/8 inch) Output x 1
- Component Video Input Y, Pb/Cb, Pr/Cr x 2
- Composite Video Input RCA x 2
- Digital Video Input DVI x 1 (HDCP compliant)
- S-Video Input 4-pin DIN x 2
- VGA Input x 1
Warranty: 1 Year Parts and Labor with In-Home Service
View current pricing on Buy.com
Additional Coupon Savings (for new buy.com customers):
Please note: all deals posted on Big Picture Big Sound are current as of the posting date and time. These deals are frequently time- or stock-limited and generally do not last. Final pricing and stock are determined by the individual deal provider, not by Big Picture Big Sound so you will need to click through on the offer link to see if it is still available. Through our affiliate relationships with many online vendors, Big Picture
Big Sound may earn a small commission on any referred sale.
